Hi All,Below the article from VAGB newsletter 51, mentioned by Mike, which I value a lot and use as a reference to set my mast each time I bring the boat back to water.marco baldan,Albin Vega 3339 SpraySetting up your riggingThose of you
who have attended International Friendship Rallies in northern Europeover the
last 20 years will undoubtedly heard of Danish Club member Kaiser Flemingand his Vega
Racing prowess. If he hasn’t won all the races he’s entered, hehas won most
of them. The only thing he doesn’t do is cross the North Sea so we inEngland
occasionally get a bit better chance of a win. Finally he has entered theRacing Class
so us mere mortals also get a chance of some silverware! When heentered the
Cruising Class (No Spinnaker) that left 5 mins after the start of the RacingClass, he
would still catch them up as well! He’s good, very good!In 2006 I
attended the IFR in Eckenforde and was lucky enough to get some valuableadvice from
Kaiser on Rig set up. He scribbled some points in the back of mylogbook and
I think I can interpret them. So here goesR..Wait for a
calm day with little movement from the water, moored alongside a pontoonin a marina
is ideal as you can occasionally walk away from the boat to get anoverall view
of the rig. Rig all your stays relatively loosely. Hoist a light line to themast head
and tie a weight to it just above the cabin roof to act as a plumb line.Make sure
the boat is not listing and is level on the water line. Fore and aft trim canbe checked
by the screws set into the bow and stern on the ideal water line.Page 10 Vega Association of Great Britain Newsletter
51If you cannot find these floatation marks you can mark
them as follows:Forward mark
is 1116 mm from the deck level measured down the stem and the Aftmark is
350mm from the lowest point of the transom measured forward along thecentre line
of the hull.It is likely
that your boat will not float to these marks because she will be heavier orlighter than
standard or the weight is unevenly distributed but they will give you anidea of
where you should be floating.Stage one.Centre the
mast by adjusting the masthead stays and check that the plumb bob ison the centre
line.Stage Two.By adjusting
the forestay and backstay rake the masthead backwards by between 1and 3
degrees, (you can see that Kaiser was careful not to give me too precise
instructions)From the
masthead to the Boom is 7.9 m according to the Vega handbookso 1degree
of rake would equal 14cms along the boom and 3degrees 41cms.Don’t query
the maths just believe. I personally have never had the nerve to try thefull 3
degrees.Stage ThreeBy adjusting
the two forward lower stays, pull the centre of the mast forward by halfits
diameter. This can be seen by stretching your plumbline tight against the rearsurface of
the mast just above the boom.Stage FourTake up any
slack in the after lower stays but do not over tighten. All the stays apartfrom the aft
lower stays should be tightened down hard taking care not to disturbthe relative
positions of the mast as set up in stages 1 to 3. I’ve never used a stressmeter on my
rigging so cannot give you a figure to work to but I think most of us aremore likely
to under tighten than over tighten.When sailing
close hauled in a moderate to strong breeze the leeward riggingshould not
sag apart from maybe some movement in the aft lower stays.My boat has
certainly sailed better since getting Kaisers advice but to do really wellyou need his
skill and experience (as well as his unique ability to reduce all weightby simply
dumping most of the contents of his boat on the pontoon before racing. Itis alleged
that his wife gave him a flask of coffee before the racing in Hundestedand he
poured the contents over the side before the race. I don’t believe this as Iknow he
would have thrown the whole flask over the side.
Mike Freeman Vega
“Jenavive” From: "Nico Walsh nwalsh@... [AlbinVega]" <
AlbinVega@yahoogroups.com> To: Albin Vega Groups <
AlbinVega@yahoogroups.com> Sent: Friday, 25 November 2016, 18:38 Subject: Re: [AlbinVega] Vega Mast Rake?
Fundamentals, non-racing: Make sure the mast is plumb athwartships, which is to say not leaning to one side. You can do this by taking a halyard and cleating it off so the shackle just touches say the forward lower shroud terminus (U bolt), then taking it to the other side and seeing where it is. Take in and ease the forward lowers until you get the mast upright. The mast can be plumb fore and aft too in my opinion. One way to do that is eyeball.When the mast is correctly up and down, tighten the forward lowers quite snug but not cranked. This can be measured with a cheap gauge if you want.Then tighten the aft lowers. These should be tight - tighter than the forward lowers as they help control forestay tension and support the mast when you are reefed. Then take in the uppers, fairly tight but not really cranked.Then check that the forestay is pretty tight. You can tighten it more by cranking on its turnbuckle, or the backstay turnbuckle. As you are doing all this frequently look up the mast track to make sure the mast is not bowing to one side or doing an S (esp when tightening the uppers). The track should be straight, although the entire mast can be bowed slightly fore and aft if you want, with the masthead and step aft of the middle section a bit - if you want.When everything seems pretty good check the shroud tension again, take in or ease as necessary, make sure the aft lowers are quite tight and the fwd lowers snug and wire and tape everything.Early in the season you will go sailing in a hard breeze and the boat will do fine and that should give you confidence in the rig for the rest of the season. The Vega mast section and rig are robust.
Nico WalshNicholas H. Walsh P.A.Admiralty and Maritime Law; Probate Litigation; Commercial LawPhone: (207) 772-2191Fax: (207 774-(Message over 64 KB, truncated)
