Steve
. . . with an aluminum holding tank?I have a 1992 H28 with an aluminum holding tank. The tank seems to be doing fine, so far (no leaks or corrosion). I have been using KO and CP faithfully, however, I have not been adding the cup of vinegar when I close up for the week. Is the use of vinegar OK with an aluminum holding tank? Are there any other things I should be doing that are unique to an aluminum holding tank? Thanks.
