L
L and W
I have made an offer on a 1984 H27. We currently own a '79 H25, and we love it, but we are excited about moving up to a larger boat. After spending all day on board the H27, I have a few questions:1. The diesel engine is a Westerbeke 2-cylinder (started right up after sitting for a year!). The Hunter owner's manual for the H27 talks about a Yanmar. Did Hunter change to a Westerbeke, or is likely that the Westerbeke was installed later? Any details or suggestions about this engine would be appreciated.2. There is a whale gusher hand pump located under the V berth on the starboard side. The pump seems to be connected to the waste holding tank. What is the purpose of the pump (evacuate waste from the head into the holding tank, or evacuate the waste from the holding tank out the deck fitting?)3. Okay, this will be the first boat I've owned with a diesel engine, so this may be a really stupid question - there is a hose and valve leading from the engine to the bottom of the hull. What is this, and should the valve be normally open or normally closed? I'm assuming that this is the fresh water intake for engine cooling water?4. The head flush plunger has a broken knob. We are thinking of replacing the entire head. The head is the original brand mentioned in the owner's manual. Does anyone know of an easy replacement? Also, any instructions regarding the operation of the head valves (is there a gate valve to control whether the waste flushes directly out or into the waste tank?) would be appreciated.Thanks in advance for any suggestions/advice!
