Upgrade from Porta-Potty
10
Catalina 27 Northport, NY
Am in the process of buying a '75 H27. Owner has taken good care of her and I am looking forward to taking her out on the LI Sound soon.
One issue I have is the Porta-Potty. I would like to know if it is possible to upgrade it to a toilet with macerator and a holding tank with proper hull fitting for pump out.
Any insight would be appreciated.
-Vince
May 24, 2004
7,237
CC 30 South Florida
The h27 came plumbed from factory with a head, holding tank and thru-hull intake and discharge ports. What may have prompted a prior PO to abandon the holding tank is a question? Check under the V-berth comparment on the starboard side and see what was done with the thru-hull valves. The holding tank was also located there. With current discharge restrictions you may not need a macerator but pumpout plumbing. I believe the h27 came equiped with a manual gusher pump. There is nothing wrong with a porta potty as an alternative to refurbish the whole sanitation system. Consider getting the best porta potty with the highest tank capacity and plumb a pump out hose to deck.
caguy
Sep 22, 2006
4,004
The Thetford 465 MSD has worked out well for me.
Apr 20, 2012
10
Thank you both for getting back to me. I'll check out the plumbing tomorrow.
