Well, just about everything I've tried has fallen along the wayside. Garmin will not respond to anything but the six foot cable. Guess the majority of installs are on power boats and don't need anything longer. Three companies I've contacted have not had the cable or missunderstood the requirement. AtoZ Industries, I thought was going to come through but only sent a single wire. Guys I need twelve of these!So being a true sailboat owner - I scavenged some computer cable from work. You remember that stuff called shielded twisted pair serial cable. That will do the job.Picture shows the rear port transom bulkhead, one frame is of the electronics mounted on white board that will be mounted to the transom. Out of focus picture of the cable. Wiring is a mess for now, this morning I fired everything up and updated the software for the 3010. Now I will splice in the wire from Garmin's short cable and be prepared to run the wires.Having fun
JimS/V Java
