C
Chris Callaghan
hi Folks! The engine should be done next week, and the mechs will re-pak the stuffing box when installing. So far have re-built the head pump, installed new macerator, chased down the water system and re-built the water pump. The hot water hose to the head sink is badly deteriorated and will be replaced this weekend. There is a wierd brass valve inserted into the hose, just below the connection to the bottom of the fitting, and it has a little 1/4" plastic hose coming off it that is 15' or so long and isn't connected to anything. What is It for? any ideas? Planning on pulling the fuel tank this week-end and bring it in to dump and clean. New running rigging next week, and got the sheaves in so will be redoing the trav./and deck blocks then too. My week-ends are too short!
