Unusual items you carry for just such an emergency
BobM
Jun 10, 2004
3,269
S2 9.2A Winthrop, MA
On another thread we were discussing emergency stuffing box hose repairs. I chimed in with the fact that a professional Captain I hired insisted I buy a bike inner tube. He said they are very useful for patching hose leaks, etc...which why I brought it up in the context of that post.
It gave me the idea for this post. What unusual item do YOU always carry for just such an emergency? Come on sailors...there must be some wild stuff on board your boats that you just will not leave the dock / mooring without.
'fess up...it will be cathartic and fun I promise. Maine Sail should be good for at least a half dozen things I will have to go out an buy.
May 18, 2007
100
Hunter 260 Dallas
Duct tape & wd40
If it moves and shouldn't = duct tape
If it doesn't move and should = wd40
Seriously though, duct tape is some good stuff and wd40 has tons of uses you would never think of, like, removing silicon caulking. It is about the only thing I have found that would ever loosen silicon. Come to think of it, wd40 is even the best thing to remove the residue from your duct tape.
Jan 27, 2007
383
Irwin 37' center cockpit cleveland ohio
wax toilet bowl rings and rubber gloves.
That S_ _ _ sticks to anything.
jimq26
Jun 5, 2004
860
3M makes a type of Extreme Tape
Fantastic stuff. Anywhere you used electrical tape before (spreader boots, etc) use this stuff. It doesn't come loose and look like hell at the end of the sailing season. Also works on pipe leaks - you name it.
Phil - you should stock some.
then use PB Blaster, far superior to Liquid Wrench, and forget about WD40, it's not really very useful (pardon the skipper who mentioned it, but try PB Blaster before you chuck your WD40, and then you will chuck it!:))
BobM
Jun 10, 2004
3,269
PB Blaster
The only thing about PB Blaster is that it absolutely will remove paint. I used it on my newly painted coupling...painted with Eastwood Rust Blocker epoxy too 24 hours earlier...took it RIGHT off. It also removed the "permanent" marker I had marked to index the coupling halves.
Dec 2, 1999
15,184
Boat full of S--T
I have a boat load of s--t on board.
Engine - all the filters, belts (some hoses etc)
Electrical - wire, connector, soldering iron
Plumbing - hose clamps, some hose
Hardware - assorted screw, nuts, bolts, washers
Misc - teflon tape, atomic tape, rigging tape, hammer, tool kit
Liquor - adequate supply of liquor, beer wine
Food stores - canned goods
Paper Products - T.P., paper towels, plates
Chemicals - assorted
Adequate amount of spare line
Extra bedding
Warm clothing
You name it we probably have it! Is that why the water line has been raised 3"?
Scott
Sep 24, 1997
242
Hunter 31_83-87 Middle River, Md
stuff
JB weld saved my butt when the nylon packing nut failed in deep water on a sat. night at Inner Harbor. Where would you go to keep from sinking at Inner Harbor?
Manny
Oct 5, 2006
983
Hunter 82? 37 Cutter Wherever the wind takes me
A Renault diesel in case of emergency
Plus Gorilla tape, emergency tape, wd-40, a jumpstarter/inverter/powersupply, a cordless drill, multimeter, an inflatable kayak, assorted hoses and clamps, bungee cords, wax ring, sleeping bags, and bottled water.
Manny
RAD
Jun 3, 2004
2,330
Catalina 30 Bay Shore, N.Y.
Unusual items and usual items
Besides the normal hand tools and duct tape is a tool as far as I'm concerned
better than pb blaster is a product called Kroil and a can of all three WD,PB and Kroil are on board
3ft piece of electrician's fish tape
cable cutters(for crab,lobster trap steel cable)
2ft X 3/8 dowel
2ft x 2x2 piece of lumber
assorted 2 to 3 ft pieces of hose 1/2,5/8
Crazy glue
Marine Tex
Cordless drill with all sorts of bits (metal & wood)
Sheet rock saw that use's sawzall blades so I have an assortment of different blades (wood & metal)
Small piece of aluminum flashing
Lots of ty wraps
all sorts of extra screws,nuts & bolts
And I'm going to buy or look in the shed this weekend for an inner tube
Jun 30, 2004
446
Hunter 340 St Andrews Bay
Nerf football
I actually don't carry one, but think I will. Fun to play with in the water, and a salvage diver told me it works great to plug holes of all sizes.
Set Hut 1!
Dec 1, 1999
2,391
Hunter 28.5 Chesapeake Bay
In addition to the "usual suspects"
one normally carries for emergencies (i.e., tools/tapes/sprays etc), I once sailed as part of a delivery crew on a 42-footer. The professional captain who asked me to come along always brought --- you ready for this? --- a bunch of his wife's old panty hose on every trip he made. Over the years, he told me that he used the old panty hose for (1) making a temporary fan belt; (2) using it for a tournequet when a crewman got cut somehow, and mostly (3) to wrap around fuel hoses to filter fuel when taking on fuel at suspect ports. I now carry panty hose in my tool locker....
Mar 28, 2007
211
Hunter 33' Cherubini Biloxi Back Bay,MS
B O O Z E
so that when something goes wrong with the boat and hubby is having words with it or about it..I can have a nice sip of something:)
BobM
Jun 10, 2004
3,269
Where is Maine Sail
I thought for sure he would have a half a dozen things nobody has thought of!
Sep 6, 2007
324
Catalina 320 Gulfport, Fl
Suture material, and a skin stapler
Along with tools and spare parts to fix the boat if we are more than 10 hours from an ER we need to be able to fix our selves. A laceration can not be sewn together after about 12 hours.
