raw water system
you asked for a ph;ysical description of the raw water system on a cat 30/m 25. Here it is on my 86 model cat 30. Starts with the thru hull valve located a foot or so to port of eng., strainer mounted on valve. Hose to raw water pump mounted on front of engine. pump is about size of your fist. Output of pump is hose: runs alongside of enge to heat exchanger (tube about size of summer sausage) mounted on rear of engine. output of heat exchanger is hose loops up into storage cabinent under sink, goes to anti-siphon valve then down and dumps into to exhaust pipe just above muffler. Water lift Muffler is white box just to port of rear of engine. Water builds up in muffler until exhaust gas pressure blows it out the exhaust pipe. Exhaust pipe is large diameter rubber hose. runs to back of boat on port side: thru cockpit lazerete, then cross over to fitting on stern. Note that raw water never goes into the engine.
