I found a few drops of coolant periodically below the engine and suspected an old hose with leak from the freshwater pump to the heat exchanger. I drained the coolant from the manifold and block with a little more than 2 quarts.
M18 manual says the coolant capacity is 3 quarts. I changed the hose. I added about 1.5 quarts which filled to about 1 inch below manifold cap as shown in picture 1.
I ran the engine at idle waiting for temperature to rise but the temperature gauge was sticky and jumped from < 120 F to > 280 F. I immediately shut down the engine, waited for it to cool down and checked the manifold which looked empty. See picture 2. I added more coolant back up to 1 inch below manifold cap and idled the motor again.
At low idle and low temp no coolant would escape from what I think is the coolant bleeder. I’ve run the engine at idle for several minutes while warm but not hot with coolant bleeder open and closed. As soon as I increase above idle or temperature starts to rise, coolant will start to leak from the coolant bleeder valve. I’ve tried running the engine to 2800 to 3000 rpm for a few seconds to try to remove air as described in the manual but coolant continues to leak from the bleeder despite trying this several times.
My questions are:
Is coolant still escaping from the bleeder because there is still air in the coolant system lines which is expanding and increasing pressure in the system when heated forcing coolant through the bleeder?
Is this a thermostat problem?
Is this a heat exchanger problem?
Is this a hose or line blockage problem?
I welcome any thoughts and suggestions about what I should try next to solve this problem.
My questions are:
