Second Star has a leaking Groco ball valve. The leak is not in the ball valve mechanism rather it leaks around the tailpiece. It only leaks when the valve is open and it is sufficiently below the water line so that there is water in hose when the valve is closed.
I've tightened the tailpiece and replaced the teflon thread tape, neither of those have worked. Over the years the leak has gotten worse. My suspicion is the threads have deteriorated and can't be sealed well enough any more. The valve needs to come out.
The problem is that it won't unscrew from the through hull fitting. Even a big pipe wrench can't budge it. There is no access to the threads so PB Blaster won't work. Any suggestions on freeing the valve from the through hull? An oscillating tool and metal blade will work, but I'd rather take a less destructive path.
The valve is a ¾" model of this valve: https://www.groco.net/products/valves-seacocks/flanged-valves/bv-series
