Greg m,
Quite a process to describe,, as no photos here on my phone. Shot story ?
Ripped 3/4" styrofoam to truncated cone shape, epoxy to underside of deck . 2 lam's of 1708 , lapped over each at center and ends to hull and from each field over the ribs. Each rib and center of deck 6-8" wide results in 4 layers. Added 6 oz woven tape at all edges and final over ribs. Reinforced with 4 more lamps, incrementally larger, at stress point for cleats, then a 3/4" ply block for post.
The 4 layer areas added to original deck end up near enough to 1/2" and the way ribs are lapped makes them 5/16-3/8" thick glass, almost 2" wide at base. No more bounce, but sorta "rings"/vibrates when pounced on
Roughly 7x7' triangle to do took near 16 hours, including demo. R&R hardware was the worst of that!
Method of application just as long or more to describe, so......mebbe later/upon request?
Regards, and best of luck
Paul
