Hi, I was reading an article on Practical Sailor about the most common issues and problems with Catalina 27s and he mentioned that owners should check the lower shroud U-bolt chainplates to see if they have been upgraded. A number of the original fittings have failed, causing the rig to go over the side. I've owned mine 27 for less than a year and I'm not sure how to check to see if I still have the older fittings. I have an 82 model; how likely is it that my boat has these? I doubt they were changed by the previous owner. Is this something I should change out right away and do I have to drop the mast to do it? I see Catalina Direct sells a Chainplate U-Bolt Retrofit Kit. Thanks
