Two-tined Fork Boat Symbol
Apr 22, 2009
339
Pearson P-31 Quantico
Any idea what sailboat uses a two-tined fork as a logo? It happens that their main is the 100% jib for a Balboa 27. I needed a 100 percent jib and foiund the main in a extra sail bag at the house. So, just asking a question regarding a two-tined fork as a boat symbol.
Feb 8, 2017
94
MacGregor MacGregor 25 Baltimore
As near as I can figure, it’s for an old Pearson Triton. Several 3 tined pitchforks on sails, but only one with 2 that I can find. A picture would be most helpful. Good luck!
Ron
ggray
Mar 20, 2016
7
Voyage 430 Deltaville, VA
You could use the main as a jib??
Seems it would take a lot of work to make that possible.
Oct 29, 2016
1,491
Hunter 41 DS Port Huron
@RobertLangdirect While main sail you have discovered may meet the dimensional requirements of a 100% jib, typically the sail cloth of the main will be much heavier than the jib which would lead to performance issues.
ggray
Mar 20, 2016
7
Not to mention having to install hanks, reinforcing the new luff, etc, and the draft is not in the right place.Panels not oriented correctly.
Buying a used jib would make more sense.
But if you were offshore and this was all you had....
Likes: DayDreamer41
Apr 22, 2009
339
Yes. However, the boat has no jib to speak of.
So, here's a story. I took the Triton(as I know it is now) Main with us as a 100 percent jib if needed. I recut (nearly well) a somewhat small and very crusty Mylar Jib from my Pearson 31, to make a 140 percent jib. We raced last Saturday. Initial wind was too much and we were way off on our start.
But daughter came home with a third place.
