My son and I applied a barrier coat of CM-15 Two part epoxy to the bottom of our sailboat. The surface was clean, dry, sanded with 80 grit prior to the application. We followed the directions on the product as to mixing, temperature, humidity, dew point, etc.
Sixty percent of the bottom has not cured after 4 days. We contacted the supplier who stopped communicating with us after we sent him a photo of the mixing directions on the can. He first told us we should have hand mixed it instead of using a drill and jiffy mixer. The instructions on the can clearly state Do Not Hand Mix. Use a drill and jiffy mixer to mix thoroughly.
We now have a sticky bottom that will never dry. I read on-line to use de-natured alcohol to remove and start over. The denatured alcohol removes some of the colored pigment, but what is left us still sticky to the touch.
The product cured in the paint trays, on the rudder and on 40 percent of the hull. The remainder in the can ( 1/2 gallon ) also cured hard.
My son and I have used two-part epoxies on power boats since 2002 without any problems, but this is the first time we used CM-15. We normally use the no-blush two part epoxy, but used the CM-15 because it is for hulls that can flex.
What should we do? Has anyone had this problem? How do we get the stuff off so we can start over?
