Twisted Turnbuckles
525
Catalina 22 home
What causes turnbuckle ends and shackles to twist and distort? I just had occasion to inspect the standing rigging on a new-to-me boat, and all but two of the lower ends showed such distortions. One even had a bend in the swaged end. Is this normal wear or an indication of a problem?
Ken
Jun 1, 2004
1,182
Catalina 22 P. P. Y. C.
Only time I've bent "T" bolts is when I got in a hurry raising the mast and didn't pay attention to what was going on with them. They will occasionally get caught in the bent position, a trick I use is a plastic cloths pin to hold them in place as the mast is coming up.
I use thin walled PVC pipe (cut 2',3',4') as shroud rollers, they will cause them to hold in a bent position at times as well.
Bilbo
Aug 29, 2005
1,265
Catalina 22 Ohio
Yes, the T-bolts can jam when raising the mast. If the shrouds are set up correctly, it shouldn't happen but ya gotta watch that.
