Twist in mainsheet
DJN51
Oct 26, 2009
377
Hunter 23.5 East Chicago In
On my 23.5 my main sheet has developed a twist,neither block are bound,removed main sheet,washed and re rigged to no effect,dry lubed both blocks,Do you think main sheet has retained a twist.
Do your blocks swivel? If so, you either need to "tie them up" (my PO did that with small twine) or buy new non-swiveling blocks. Garhauer is a good source.
Jun 22, 2012
39
Catalina 27 std dinette mission bay
remove swivels from blocks..... re reave mainsheet to counteract twisting.
DJN51
Oct 26, 2009
377
Victory,Tried that,Didn,t make a difference.They are swivel blocks.If I change to ridged as Stu suggested how will the mainsheet not jamb at fiddle cam cleat because of angle of sheet.Blocks are mid boom.
Joe
Jun 1, 2004
8,351
Did you know that most blocks can be locked so they won't swivel?
You might try reversing the sheet..... also reverse the direction of one of the legs.
If you have a picture it would help...... like..... a lot!
Is the twist at the traveler end or the boom end.....
What usually causes twists or binding in the multiple purchase gangs such as the mainsheet is one of the blocks has been turned inside out by mistake.
Joe........ aka Victory
DougM
Jul 24, 2005
2,242
Beneteau 323 Manistee, MI
The sheet may have a bunch of hockles in it. Take it out and drag it behind the boat while motoring andit will untwist itself. Then reverse it when you reinstall.
If you're in salt water, you might want to try simply cleaning them on the dock.
