I have a macerator hooked up to my gray water tank, and up until last week it worked, no problems. Last week however, I noticed the macerator wasn't coming on like it normally does. In the gray water tank is a standard bilge float switch that activates when the tank starts getting full. There is also a manual switch I can use. The manual switch works great (thankfully!). So I'm thinking float switch. I tried manually lifting the switch, nothing. I jumped the connection, by-passing the switch, still nothing. Ok, float switch is not the (only) problem. I put the multimeter on the connection, 13.ishV, but no love.
I'm pretty nooby with electrics, but if you give a pump 12V and ground it should run, no?
Looking forward to any suggestions!!
