Tropical Depression 11
JamesG161
Feb 14, 2014
8,074
Hunter 430 Waveland, MS
This one is different than all the Invest's being tracked now.
TD 11 popped up over night, most likely from a Satellite pass.
This is much closer to the Antilles than Invest 99L [trailing back East]
The upper level steering winds will push both storms on roughly the same path.
Both storms are running into the Eastbound upper winds and should not get much larger.
But...
All it takes another Satellite pass for TD 11 to detect higher winds and we will have
TS KIRK
Dammit Jim..
JamesG161
Feb 14, 2014
8,074
As a side note...
NOAA has several low altitude "Back Scatter" Satellites that the combination will cover the entire globe in few minutes [I recall <15 minutes].
They give even winds from N Pole to S Pole.
When they get repeated "interference' in the same "spot" it may be an indication of water surface contamination.
Here is the ASCAT satellite link
https://www.ospo.noaa.gov/Products/atmosphere/ascat/winds.html
Jim...
PS: Most of tracking model data is Satellite, but still the best data is Hurricane Hunters and data buoys.
Here is an interesting image.
Shortwave Absorbed Radiation (SWAR). Absorbed solar radiation is the difference between the incoming solar radiation at the top of the atmosphere and the outgoing reflected flux at the top of the atmosphere.
Likes: JamesG161
JamesG161
Feb 14, 2014
8,074
LMAO :laugh:
The next question who was brave enough to light it!!:pimp:
Jim...
PS: Actually the burp is CO2 and the Fart Methane.:ass:
I do not believe Cows burb. They have two stomachs so the cause to burp is not there.
They do fart.
JamesG161
Feb 14, 2014
8,074
Well they do...
"This incessant belching expels an impressive volume of greenhouse gases—mostly methane and carbon dioxide. Added up, burps from cows account for 26 percent of the United States' total methane emissions."
It was proven in a..
High STEAKS Study:cowbell:
Jim...
