traveler
hello dan, the standerd fix is, in the cockpit side of the transom, you will cut about a three inch diameter hole through the skin under each leg, then reach up into the void with a (I think)1/2 inch socket and tighten the bolt on each leg. I had to remove the traveler , run a tap into each leg to clean the threads.And I still had to shim the bolts with modified washers, but it is tight. Also check the archives, this has been covered several times before. good luckjohn
