Removing pins
> Do you recall how you removed the pins,> are they threaded?Pins are not threaded. I think I just pulled them out with needle-nosed pliers, but I can't remember for sure.When I put them back together I used a little bit of glue to make one of the pins a bit more secure.The pins and the end caps should never take any serious force. Make sure that the traveler control blocks are locked so that they can never slide and push against the end caps.Also, I drilled another set of holes, for accepting the set screws in the control blocks, further out on the traveler bar in order to increase the range of movement of the traveler.
