Benny17441;1185603....As far as winterizing the trap said:In Florida, the traps keep the Palmetto bugs out
If, using your picture, the drain hose went straight down to the drain, water would probably gush up due to rocking action.,,,,drains exit at 90 degrees and loop down hugging the hull to the through hull. ...
I don't know the ones here in Tampa don't fit in the plumbing fixtures. If youd put a saddle on them you could probably ride them.In Florida, the traps keep the Palmetto bugs out
Not to worry... he owns a boat, so cannot afford REAL gemstonesThat's probably best used to catch your wife's earings or diamond ring,...
