trany
KD3PC
1,069
boatless rainbow Callao, VA
usually there is a tag on the box that will tell you what to use. Failing that you will need to identify the box your boat has and read the correct manual for it.
There is no one ATF that will work in every box, some boxes actually use oil.
The wrong stuff will affect performance and cause wear parts to not work.
YMMV
Dec 14, 2003
1,450
Hi,
d
Does anyone know what kind of atf the transmission take.
THX
As mentioned on previous post, there is a tag on the gearbox. It will tell you what type of transmission it is. A Yanmar engine of your vintage probably has a Kanzaki tranny and it probably takes straight 30 grade motor oil. Please do check the tag carefully before putting anything in it as you might create problems if using the wrong type.
Johnb
Hunter 37-cutter Richmond CA
Don't get opinions. Do read the tag on the transmission and then look up the right lubricant.
If it is ATF (automatic transmission fluid) and the boat is an older model the recommended one may no longer be available and you should check for compatibility. Generally there is no problem in that regard.
Jun 2, 2004
5,802
On the older boats with Yanmars the transmissions were Kanzaki. Those used the same oil as the engine. I used generic 30w for the eight years before I replaced engine and tranny.
jphud
Nov 18, 2010
70
1980 Hunter 37 C Saugerties
How hot does your Trans case get,
Shaft and stuffing cool, case almost to hot to hold hand on on after 2200 rpm for about 3 hours.
1980 H37C
Johnb
Exercise an abundance of caution.
The 2QM30 and 3QM30 with YP-7m and YP-10M transmissions used the same oil as the engine
The 2QM30H and 3QM30H with Kanzaki Hurth transmission (which I have in my 1983 HC37) uses ATF.
Before changing the oil check - Google "self harming"
