Transmission shifter
P
PJE
I have a problem shifting my transmission from neutral to forward. I am aware of two adjustment points; where the cable sleve is attached to the transmission and on the bolt that connects the cable to the transmission shifter lever. Both are adjusted as far back as possible to get the transmission to shift into forward, but the shift lever still hits the pedistal steel, and the shifting to forward is not a certainty. Has anyone else had this problem and how did you overcome this? Regards, Pat
C34 Association website
Pat suggest you go to the link. C34 website. Stu
Tom S
PJE What year C34MKII do you have
Here is a bit of info on the same issues with the C36 (same engine same systems) http://www.catalina36.org/site2004/Article_transmission.htm Do you get a full 30 mm throw in forward or reverse. As an FYI you might want to read this too http://catalina36.org/eve/ubb.x/a/frm/f/6186056212
