Transmission position while sailing
Jun 3, 2004
42
Catalina 34MKII 1717 Merritt Island, FL
I have a Universal 25 XPB engine. When sailing, is it best to leave the transmission in neutral or reverse? Thank you
Sep 20, 2006
2,953
I think this one wins the prize for the most often asked question. Sorry, couldn’t resist...
Real answer - it depends on what the transmission is, not the engine.
Along with Anchors and how to make coffee on board..... :biggrin::biggrin:
And yes, depends on the make of the transmission and also if you have a fixed blade prop, feathering prop or folding prop.
May 24, 2004
7,228
CC 30 South Florida
And for the 10,000,000,000 time, "follow the manufacturers recommendation". No, really there is a lot of information on this subject in the Forum Archives.
Likes: NotCook
Feb 21, 2013
4,638
Hunter 46 Point Richmond, CA
Some, like Don, will recognize their posts in these treads on the same subject. Below is Universal 25 XPB engine's manual (link attached) and Hurth HBW transmission position while sailing warning.
Catalina 34 transmission remarks: The Right Transmission Gear for Sailing - c34.org
Likes: FastOlson
And to summarize the advice given in the past - Your Universal *probably* has a Hurth transmission, which are generally OK in reverse or neutral, your choice. Neutral is a bit noisier and maybe more wear; reverse is quieter but more drag with a fixed prop. Absolutely never leave a Hurth it in forward As it will wear the clutch plates.
With a Yanmar, that usually have Kanzaki transmissions - Neutral is the general recommendation, as the transmission isn’t designed to hold against the torque of the prop if locked in neutral. If you sail in reverse it might jam that way, and if that happens do not try to force it out of reverse.
Replace any of the above with the recommendations of your transmission manufacturer if there are differences.
Nov 13, 2013
723
Catalina 34 Tacoma
Either one is fine although if in neutral, the prop will spin while underway. In reverse, the prop will not spin. If your looking for an extra 1/3 knot, neutral is best. If your looking to save the minimal wear on bearings, reverse is best.
Mar 1, 2012
2,182
with my Yanmar, in my Cross 35 tri, I HAD to keep it in reverse. In neutral it would drive you nuts, and in forward it would bump start the engine somewhere around 12-14 knots boat speed
Likes: capta
May 24, 2004
7,228
CC 30 South Florida
These transmissions are pretty tough so I would not worry about bearings and gears wear in either instance. Yanmar has mostly switched positions and now recomending that the constant mesh gearboxes are allowed to freewheel in neutral. The gears and bearings in these transmissions are constantly being lubricated when turning. Having to slow down the boat to shift out of reverse gets old real quick.
Dec 29, 2008
806
Treworgy 65' LOA Custom Steel Pilothouse Staysail Ketch St. Croix, Virgin Islands
Not according to many, as the spinning prop presents drag the full radius of the turning prop, whereas the stationary prop presents a smaller area of resistance. I’m sure at least transmission makers and or prop makers have done tests to determine the relative drag to come to those conclusions. Our Velvet Drive says it doesn’t matter as it doesn’t lock regardless of the gear it’s in. The individual transmission maker’s recommendation is always the right answer.
