Do you mean it throws you into forward or reverse? That is hard on the transmission. Not to say if you attempt the maneuver in a tight environ you might be meeting new neighbors in a compromising manner.then over shoot.
If it's anything like my transmission, it's inside the transmission housing. There are spring-loaded bullets on the output gear assembly.Where is the lever detent located?
Access isn’t too bad for the C310. You’ve reminded me that I should consider doing this myself.Spoke with Edson today. 12 year old cables may cause this as most of you have said. How big of a PITA is this?
