transmission heat exchanger question
CYQK
Sep 11, 2009
605
beneteau first 42 kenora
Mounting new exchanger on new zf12m gear
Anyone know of a substance to apply between them that will enhace heat conductivity and prevent corrosion??
Thks
JerryA
Oct 17, 2004
550
Hunter Hunter 170 Sandusky Bay, Lake Erie
Not knowing what it looks like, my first thought is heatsink compound. You know, the white stuff used in computer equipment.
CYQK
Sep 11, 2009
605
Jerry
Thks for the reply..
Its just basically two flat surfaces will look for your suggestion
jviss
Feb 5, 2004
7,090
Tartan 3800 20 Westport, MA
I would worry less about the thermal conductivity and more about corrosion; thus, though expensive, I would use Tef-Gel. It has lots of other uses on boats, too.
Tef-Gel
