I made the same search last year.
Hi Faith,I decided on the H260 after much searching including a trip to the Boatshow at Annapolis, MD. There was a lot to look at there and you could walk back and forth between the boats to compare. With a hefty truck like a one-ton duelly you can pull something like a Hunter 280 or 290 or a 27'Catalina (or other similar boats), but you'd still have to have a crane to step the mast and a travel lift to launch the boat. So you'd probably just be towing the boat to and from home once a season. In my judgement the H260 was was the most "cruisable" boat that you could get to and from and in and out independently, and a Chevy Suburban in good shape should do fine to pull it. You'll want a transmission cooler if it is an automatic.Hope this helps,Joe C. in NC'01 H260Windward Passage
