Brent
I have a hunter 23.5 which I purchased last year. The boat loads very easily on the trailer except that the front roller contacts the bow very high when loading, forcing me to use the winch to pull it up and over to its final resting position. This appears to be causing some damage to the bow and I would like to know if anyone else has had the same problem. I have noticed that the newer hunter trailers have this forward roller farther back on the trailer than mine is positioned. I suspect that I could change the bunk angle or add another roller to lessen the impact that this has on my bow, but I'm not sure which would be better. Other sailors have also suggested that I might try an extension so that I can put the trailer out in deeper water as the boat rides well once its on the trailer. Any suggestions?
