I took another data point on the power consumption of this electric ice chest now that it has warmed up considerably here. Remember back in mid January (Lake Havasu Arizona), I had measured the 24 hours consumption and the fridge only used 9.5 amp hours.
I just did the same test again April 3 here in Lake Havasu during an unusually warm spell which had 24 hour low temp of 63F and a high temp of 91F and of course significantly longer days compared to nights. Fridge temp was set to 40F and contents was a gallon of milk and six pack of can drinks. Batteries were fully charged and at 5:30 PM, I removed all charging sources and the only load was the fridge. A Xantrex linklite battery monitor kept track of amp hours. I disabled the night time shut off circuit so the fridge ran the entire 24 hour period.
For this data point, the amp hours used in 24 hours was 28.1 amp hours.
In theory (look up R value definition to verify if you wish), the energy loss is proportional to the difference in temp across the insulation. Since the fridge inside temp was set to 40F, you would expect to double the energy loss going from an average external temp of 60F (delta = 20F) to 80F (delta = 40F). And you would expect the energy input to the fridge to be somewhat proportional to the energy loss. So.. not too surprising that the power used went way up on a fairly warm day.
Solar output varies a huge amount with all of these variables: time of year, latitude (insolation), cloud cover, temperature, flat or angled, type of controller, etc. The only solar predictor that I somewhat like is a unitless equation:
Solar panel rated power * N = amp hours/per 24 hour period
I have measured N at about .31 once and generally just go by that N varies from maybe .2 to .5.
For my particular case where I am powering this fridge with a 160 watt solar panel and for the amp hours I just measured, the mininum N that I need is
28.1 amphours / 160 watt rated panel = .175 This is under my assumed range of .2 to .5 so I think I have a good chance of the fridge being sustained by the batteries even on a fairly warm day and with the solar output on the lower end because of conditions. I will find out later this summer but expect to still have excess power. The only bad thing is that the closer you are to barely having enough generated power is that it works the batteries harder so they dont last as long.
FYI, at the bottom of the cold side is a lexan platform that has standoff that are just PVC pipe rings glued on with contact cement.
The compressor side has a lot of ventilation. Top and bottom louvered vents on the front, the whole end is open with a screen mesh and the top cover has vent holes on the back and end sides.
Aluminum guard keeps items in the fridge from damaging the cold plate while sailing.. Stuff definitely gets thrown around (beer bottle projectiles). Temp measuring detector shown in the lower right side of the pic.
