Towing vehicle (Chrysler Pacifica)
Lee Y
Jun 5, 2004
43
- - Muskegon, Michigan
Does anyone tow their H23 or something of similar weight with a Chrysler Pacifica? I'm interested in how well it tows, and pulls the boat in and out of a launch. I need to replace my Jeep Grand Cherokee. We bring our boat to the marina in the spring, which is about 45 miles from home, and back home in the fall. The boat is not in a slip. The boat is all rigged, so we launch it when we want to use it, which is usually a couple times a week. The launch is fairly steep. It's at Harbour Towne Marina in Muskegon Michigan.
Thanks for your input
Lee
KD3PC
1,069
boatless rainbow Callao, VA
Good Luck,
My MIL has a pacifica, and although it rides well...it is no towing machine at all and with the 23 weighing over 2500 lbs, empty...you really don't have much margin when you add trailer and equipment, as it maxes out at 3500 lbs...which in IMHO is a bit high given the power train.
Hers does have all wheel drive, but was not great in the snow this year, even with that...we pull a small landscape trailer with a riding mower, and a 18' sailboat, but even those light loads kill mpg..
I would sooner get an older full size vehicle...
all the best
dave
Clark
Jun 30, 2004
886
Hunter 280 Lake Guntersville, AL
Since you are only towing it a couple of times a year, that would have a low impact; just be very carefull. I'd worry more about the 2x/week launch & retrieve; a lot of stresses on a light duty drivetrain. Why a Pacifica?
Apr 5, 2010
16
Hunter 23.5 Eagle Creek Lake
I have a Chevy Trailblazer that I use to tow my 23.5 without any problem at all.
May 2, 2010
9
Hunter 260 lake
It looks like the towing capacity is 3500 lbs with a 350lb tongue weight.
If it is a very steep ramp, consider an all wheel drive rather than front wheel drive version.
May 25, 2004
981
Catalina Capri 14.2 1670 Rochester, MN
Pulling a Hunter out of the water is the real test. If the tow vehicle is light on the drive axle, the wheels are going to slip regardless of the towing capacity.
My little jeep pulls the boat right out because its 4WD. My 2WD pickup, with higher tow rating and horsepower, can't because there is zero weight on the drive wheels.
