i Towed A H260 On Some Long Distance Trips (1800 Miles One Way). The Truck Was A Silverado, 4x4, 5.3 Lt, With The Trailer Towing Package, Limited Slip Diff. It Towed It Quite Well. I Always Had Lots Of Weight In The Truck Box. A Lot Depends On How Far And How Often You Will Be Towing. Florida Is Quite Flat, Good Roads. I Think You Will Be Fine Unless You Intend To Tow Across The Country.
One Tip I Will Share. Adjust The Trailer So The Bow Of The Boat Is Down Slightly. If Kept Level Wind Can Get Under The Bow And Lift All The Weight Off The Ball. Resulting In That Wiggle When A Truck Passes. By Keeping The Bow Down The Wind Acts On The Foredeck To Increase The Tongue Weigh With Higher Speeds, Wind Gusts, Truck Traffic. All Situations That Some Find Causes Instability As The Weight On The Ball Goes Down.
I Found The Surge Brake Cylinder Needed Yearly Service To Work. I Think It Was Rebuilt Each Year I Owned It.
The 260 Is A Great Boat, You Will Not Regret Buying It. Great Boat For The Keys, We Did A Florida East Coast Cruise To Keys In 2010 With Our 260, Slide Show Here,
https://www.dropbox.com/s/hqf3ehnwds00qnk/florida_keys_cruise_2010_640x360.mp4?dl=0
Good Luck, Bob
