Toilet Replacement 373
Pfloyd
Oct 29, 2018
2
Beneteau 373 Clear Lake Texas
I am thinking about upgrading my toilet from a Jabsco manual to an electric. Considering Dometic and Raritan. I understand there are some issues with pump head pressure because the tank is vertical. I was wondering if anyone has made this change, any advice would be greatly appreciated. Especially with what will fit in the 373. This is a two cabin layout, Thanks
Likes: stevemitchell
Pfloyd
Oct 29, 2018
2
Thanks very much, I have read that the Raritans are very good about tanks above the head. I was actually more concerned about what type of toilet would fit. I was looking at the Raritan Elegance but I think it will be too big. The one you installed appears very similar in size to the Jabsco I am removing. I will also need to use freshwater as the water where I normally sail creates an odor problem worse than the septage. Thanks for the feedback
Jan 12, 2016
140
Beneteau 311 Seattle, WA
Ah yes, I did the same investigation. I wanted the bigger bowl of the Elegance, but there was no way it would fit comfortably. Good luck!
Sep 6, 2011
10
Beneteau Oceanis 373 Starr, SC
Several years ago I purchased a Jabsco electric toilet conversion kit for our ‘07 B373. It was a well needed upgrade.
May 29, 2016
6
Beneteau 343 Westbrook, CT
I replaced Jabsco Head on my 343 with Raritan Freshead. Fit same bolt pattern as Jabsco. Raritan has strong pump. I have had so many issues with Jabsco. Replace pump once and joker valve 2-3 times. Jabsco joker valve poorly made and folds with pressure from water column to top of holding tank. Poor choice by Beneteau.
May 29, 2016
6
Rarity joker is better. Install vertical. Raritan has stronger pump plus the fresh water was a great benefit.
