Tipping angles
dLj
Mar 23, 2017
4,812
How about the oil pick-up inside the engine? Will it be pumping air instead of oil? Best to check with the engine manufacturer before attempting this procedure.
Your question spurred me to look through my engine manuals to see if this is addressed. I did not find anything. I know installing engines, there is usually a fore/aft tilt that the manufacturer typically specifies.
Marine engines must be able to handle a certain amount of heal, but your point is well taken. I know I've watched/helped pull boats through areas (usually deep draft boats going into entrances with a shoal that has to be passed over) where the sail boat was running it's engine while being both towed from the front and being healed over by a boat on the side attached to the mast head. Was that good or bad? I don't know for certain. No one ever complained...
dj
