Thank You again. I also have just received some Nylon snap-in thrust bearings that I hope can be put into the holes for the tiller pins. (Im still a new sailor and don't have the lingo down). The rudder has always seemed sloppy and bushings should help. Now to check to see if there's enough "meat" on the brackets to ream . email me if interested. mmehne47@hotmail.com
Thank you both. Good stuff and what a plus that you would help. I went thru 6-8 systems (home made & commercial) before I stumbled on the Tiller Cultch. (love it!) Brian: I put the bushings in yesterday. Had to ream the holes to 9/16" to fit . It was hard to do as I wasn't sure of fit or durability and once reamed there's no going back. I could end up with more slop. Finally decided to go for it as the orig. holes are not round. Prob. a stamped out then bent to shape part. The bushings fit and Rudder fits and feels great. As to durability- doesn't look like its overkill but should standup. Failure while sailing would be of little concern and replacement cheap and easy. If it totally fails I think there's enough "meat" left to ream larger and go with an even beefier bushing. I left the packing list with numbers (cat. #s changed) at the shop but will get them to you soon.While I will defer to Jackdaw on just about anything, I have to say on the 192 and probably the 222, a Spinlock handle type system is probably overkill. I have also used the Forespar style on a Precision 18 and Precision 21.
On my 15' Harpoon, I had a Harken stick type that looks like a golf club. I used to sail that hiking harder with toe straps, and I would hold the stick Laser style with my thumb underneath pointed at me, and my finger wrapped over the top, and the mainsheet held by my thumb. I would not use such an extension or such a grip technique for a non-hiking boat, e.g. that Harken extension ain't goin' on the O'day. Maybe if I were to get a Force 5 like I want, or if someone were to give me a Laser![]()
For sure, these things are matters of taste. I'd have no issue with someone going either way. On bigger boat (ours is 24.5 feet LOA) any maybe a 22 I like the hand position of the grip. Like below. Compared to your picture I'd go this way, but thats just us. And boat design also factors.While I will defer to Jackdaw on just about anything, I have to say on the 192 and probably the 222, a Spinlock handle type system is probably overkill. I have also used the Forespar style on a Precision 18 and Precision 21.
