Thru Hull is weeping haulout 60 days away.
478
Irwin 41 CC Ketch LaConner WA
Gary
You are asking a very dificult question that has serious ramifications if somethinh happins, and I'm not trying to speak for anyone else ,but you have to get this fixed , It is not in a seaworthy condition but it has held, I't not getting better it can only get worse. My sugestions 1) Secudual Haul out ASAP ( Make sure yard knows whats up!! ) 2) Try to get a friend in a power boat to follow you 3) Slather on somemore stuff before the trip 4) Support the Sea Strainer 5) Triple up on bildge pumps 6) Make sure engine is ready for the 15 mile run and more fuel then needed 7) Have wooden plugs aboard If I dont mention safty gear someone will hammer me but I feel thats a givin "It's the Law" right. You will most likly be just fine but as stated above it has to be your decition to move it from the dock. The way I look at it is this. It has to be done. It can eather sit at the dock and sink without you getting wet. or it can sink with you attempting to move it with you on board. I personaly think it will make it just fine and I woud move it if it were my boat with the above conditions met, it's better then the alternative.
Dec 8, 2007
478
Gary
Gary_H
Nov 5, 2007
469
Cal 2-25 Carolina Beach NC
I guess it comes to this
It can't be fixed sitting in the water. It has to come out. I will take all the precautions I can. At least its straight up the ICW and I suppose I can run it aground if I have to. Thanks All. I'm going to try to do it this week while the weather is warm and calm. I don't mind telling you I'm nervous as hell but I guess I got no choice.
Gary_H
Nov 5, 2007
469
Dec 8, 2007
478
Having someone
follow you will help a GREAT deal with your nerves. PS: Use Mainsails instalation technique if possibal..
Dec 8, 2007
478
Having someone
Ross
Jun 15, 2004
14,693
Better than having someone follow you would
be having someone else on board. Some one who could monitor the boat for trouble and could assist when and if you need damage control. This isn't like the bottom of the boat is going to fall off but if the fitting breaks 30 seconds after you look at while you are underway and you don't look again for ten minutes there could be an awful lot of water in the boat before you find it. Just be prepared for having the thing let go and be able to stuff a rag into it. You are not dealing with high pressure water here. Just 2 or 3 feet of head. That is 1 to 1 1/2 pounds per square inch. You can stopper a sink drain with a wash rag but you have to be there to stop the leak when it starts and you can't do that and helm the boat at the same time.
Ross
Jun 15, 2004
14,693
Dec 8, 2007
478
I would propose both
as if it does let go your done running your engine also and now you have a tow boat.
Dec 8, 2007
478
Ross
Jun 15, 2004
14,693
If this is the engine cooling water intake is there another thru hull that could
engine?
Ross
Jun 15, 2004
14,693
engine?
May 11, 2005
3,431
Seidelman S37 Slidell, La.
Rigid connection
Is there another thru hull you can jury rig as Ross suggested, and not use this one with the strainer hanging on it. Maybe a sink drain or something you could get a hose onto. Another consideration would be to try and get a short section of hose between the valve and the strainer, to relieve the strain and vibration. Of course this may require too much pressure on the thru hull. At least find some way to tie up that strainer and get as much strain off the fitting as you possibly can.
May 11, 2005
3,431
Rigid connection
7,397
Alden 50 Sarasota, Florida
Gary
Nit sure if our comments have thoroughly scared you away. Hope not. My observation from being here a while is that we generally tend to give sound advice and if anything, also tend to be on the cautious side which is usuallly a good thing. All of the comments here are both. For all the justifiable pessimism expressed previously, it's not impossible that this situation has existed since long before you took ownership which also isn't to say it could fail tomorrow; only that it is in all likelihood not a show-stopper which would prevent me from getting to a haulout yard a few hours away. My point being that in a confined waterway such as you'll be in, the worst thing that could happen is it will begin to leak excessivly but not to the point it can't be controlled. It's alot more disconcerting to look down from the cockpit and see water when you have no clue from where it is coming. In your case, you have a head start.
7,397
Gary
Ross
Jun 15, 2004
14,693
I even considered a can of urethane foam blown in around the strainer
It would make a terrible mess but one that yields to power tools.
Ross
Jun 15, 2004
14,693
Feb 6, 1998
11,703
Here's What
Here's what Groco one of the marine industries largest suppliers of through-hull, seacock and bronze in-line valves has to say about using in-line valves as opposed to seacocks. 1) An inline valve has no means of attachment to the vessel hull or backing plate/block, so the valve can turn or loosen from the through-hull fitting with vibration or with normal use. 2) If the connected through=-hull fitting becomes damaged or broken, as might occur if the vessel struck a submerged object, or if athe fitting was inadvertently damaged or broken inside the hull, there would be no way to shut off the flow of water into the vessel. 3)In-line valves (ball valves or gate valves) have NPT threads which are NOT compatible with NPS threaded through-hull fittings (unless the through-hull fitting is machined with "combination thread"). Installing an in-line valve onto a through-hull fitting will create a mismatch of threads resulting in minimal thread engagement between the valve and through-hull fitting, and an UNSAFE installation. Property damage, personal injury, or both could occur. If you choose to utilize an in-line valve as a seacock, the through-hull fitting used MUST have "Combinations Thread" P.S. Combination threads must be custom machined and are NOT readily available! there are many boats out there running around with MINIMAL THREAD ENGAGEMENT between the through hull and in-line valve.....!
Feb 6, 1998
11,703
Here's What
