Marcia
I am in the process of preparing my boat to have the mast pulled next week. A friend assisted me with pulling the electrical wiring, but in the process we found that the 12v thru deck electrical pass throughs could stand to be replaced. What I want to replace are the (bronze?) female threaded caps that screw onto the threaded male deck mounted receptacles (which are fine). The female caps have holes in the tops with rubber washer type things that allow all the 12v wiring to pass from the mast, through the deck and on to the batteries. (There are 4 of them in all). I've tried to Google everthing I can think of from "marine thru-hull electric connectors" to dozens of various other queries with no results. Does anyone know the correct terminology to use or better yet, point me to a web site that may carry such objects. These connections have been the source of leaks in the past and I'd like to repair the problem rather than just put gobs of silicone all over them. Any help/advice would be appreciated.
