Through-Mast blocks for running internal halyards
Mike Kohler
I have seen on other (newer) Catalina 27's, a double-pulley (block) that have been installed on both sides of the mast for running the halyards inside the mast. Where can I get a hold of a couple of sets to install on my mast? Also, the ones I saw in use also use two sets (one per side) of stacked blocks for routing the halyards around the sliding hatch and back to the cockpit. thanks for any help! Mike Kohler 814-881-7581 mike.kohler@verizon.com
Mar 31, 2004
244
Catalina 380 T Holland
Probably from Catalina
for tthe mast exit blocks. If I understand your description correctly, the organizers (the stacked turning blocks) are from Garhauer, and can be ordered directly from them. Steve Alchemist C-320
Joe
Jun 1, 2004
8,360
Sailboat hardware
You might find that particular exit block at Catallina Parts Dept. Call the factory. Catalina Yachts • 21200 Victory Boulevard • Woodland Hills, California 91367 • Phone 818 884-7700 http://www.catalinayachts.com/ In any event you're talking about exit blocks, cheek blocks, organizers, cleats clutches etc. Garhaurer, Harken, Ronstan, Schaeffer, Antal are some of the manufacturers... Start with http://www.garhaurermarine.com.... the other brands are available at any chandlery... westmarine, boat us, defender, etc. Go to http://www.catalina27.org/ and investigate the parts manual online. You'll find diagrams of the masthead and other parts that you might need. You can order those parts from Catalina.
