Replace them with bronze or marelon
This is a known issue with the older Cat 27. Go to the association website to find a list of other issues. (other main ones are keel bolts and chainplates) http://www.catalina27.org.The factory installed very cheap gate valves that were glassed directly into the hull. There actually was no thru-hull fitting. The through hull is the mushroom shaped fitting that clamps a connector pipe to the hull. A ball valve is then attached to this connector. Your plastic plumbing will lead off the valve. Here's a better explanation.http://www.westmarine.com/webapp/wcs/stores/servlet/westadvisor/10001/-1/10001/seacocks.htmLook at your system carefully to determine if the previous owner has already installed a properly mounted, mushroom shaped through hull. There should be a backing plate against the hull with a flange mounted on it, allowing the mushroom's extension to protrude and be bolted down. A separate ball valve should be attached to the extension. If you have this but can't tell if it is marelon or hard plastic, change it. If there is just a pipe with a valve on it, change it to a proper system. this:http://www.westmarine.com/webapp/wcs/stores/servlet/product/10001/-1/10001/31577/10001/217/70/11 or this:http://www.westmarine.com/webapp/wcs/stores/servlet/product/10001/-1/10001/17318/10001/217/70/11While you have your boat in the yard you might ask the yardmaster to give you his opinion if you're not sure.
