Throttle Creep (no, not the guy on the boat next to yours)
JimLor
Nov 21, 2011
75
Pearson Pearson 28-2 Deale, MD
Looking for some suggestions on stopping throttle creep. Our boat, Tyde What May, apparently likes to operate at 2450 rpms no matter where we set the throttle. I can set it at 3000rpms and within 30 seconds it's back to 2450. While that is actually a comfortable cruising rpm (generally 5 to 5.5knots), I'd like to be able to set it higher and not have to hold it.
I know this "should" be an easy fix, tighten the cable or tighten the actual throttle on the engine, but I took a quick look yesterday and didn't see anything that stood out as the adjustment.
Any comments, suggestions, experiences you'd like to share?
Thanks.
Jim
Re: Throttle Creep (no, not the guy on the boat next to your
If you have an Edson pedestal, there is an adjustment nut inside the binnacle. www.edsonmarine.com has the instruction manual on line.
Jun 9, 2008
1,850
- -- -Bayfield
There is also a cable brake you can insert in line on the slipping cable. It is a SS clamp that has a bolt that when tightened, applies pressure on the cable so it does not slip easily eliminating your creeping cable.
JimLor
Nov 21, 2011
75
Thank you both. I did some research and found several remedies folks had used. Then I found the Edson engine control manual on a site other than the one Stu posted - thanks Stu I'll use yours in the future.
Really a frustrating situation; I'll take out the compass and use the adjusting nut. Thanks again.
Jim
JimLor
Nov 21, 2011
75
Well, not so fast. I took the compass out and tbere isn't any adjustment screw/nut! Maybe i'll install one.
