This may seem obvious to others but...........
Ross
Jun 15, 2004
14,693
One of the hardest things for me to find when I was learning how to sail was "how to sail slowly" . It seems like everyone is obsessed with sailing fast but sometimes sailing slowly is very useful. Sail trim is all about how to get the most out of your sails and boat, but when it is blowing stink and you are approaching an unfamiliar area do others on this forum feel the need to be able to continue sailing slowly and cautiously instead of hoisting the cast iron jib?
Oct 22, 2008
3,502
- Telstar 28 Buzzards Bay
Yes, learning to depower a boat is a very good thing... by this I mean using sail controls, like the boom vang, outhaul, cunningham, jib fairleads, traveler, to reduce the power of the sails....as well as tucking in a reef or two.
Heaving to, lying ahull, forereaching are also good tactics.
RAD
Jun 3, 2004
2,330
Catalina 30 Bay Shore, N.Y.
I always remember the saying when in doubt let it out and that seems to work to slow down and have better control but I need to learn more skills in sail control so I really know what I'm doing
Sundance Sundance 20 Weekender Ninette, Manitoba, Canada
I think the time that I most impressed myself about the power of sailing slowly, was during a sandwich break wherein I showed my friend how to set the boat in a 'hove to' position. We ate our sandwiches and quenched our thirst while still moving forward at about a knot. The boat behaved itself beautifully, but I did not know how well, until we were fininshed lunch, and upon my confirmation that we were both ready to go, lunch stowed, crew in position etc, I let the windward sheet out to bring the jib into its close reach positon, trimmed the leeward sheet, and manouvered the tiller accordingly. Within a few seconds we were moving at hull speed. My buddy looked at me indicating that he was quite impressed, but I was even more impressed at how well the boat had behaved, until I 'dropped into gear' and we shot off. I will never forget that lesson on how well I was able to control the boat, but especially when I needed to slow down.
Manny
Oct 5, 2006
983
Hunter 82? 37 Cutter Wherever the wind takes me
One of the first things I learned was not to sail as fast as possible, mostly a function of keeping the admiral comfortable.
Manny
BobM
Jun 10, 2004
3,269
S2 9.2A Winthrop, MA
I still have a lot to learn, but agree that knowing how to depower a boat and sail slower and or safer is an important lesson. It is fun to be out when it is windy, but when it is gusting to high velocities relative to the average wind speed it can be hazardous. Rolling up the jib and dumping some wind from the main or reefing makes for a more comfortable ride with little loss of speed.
May 5, 2006
1,140
Knutson K-35 Yawl Bellingham
It comes in handy when you're waiting for a ship to clear your tack. Oh Joy handles pinching nicely.
Tim R.
May 27, 2004
3,626
No need for this skill Ross!
Just kidding. This is a necessary skill for racing and a successful start. Sometimes the wind pipes up approaching the line and you need to slow down. I usually err on the side of slow and do not roll out the full genny until the 1 minute warning gun. Even then I sometimes need to release the sheets to slow down and then power back up to get the timing right. Out of 13 races this summer, I probably crossed the line first in more than half and nailed a few right on the line.
Mike B
Apr 15, 2007
1,013
Beneteau 43 Baltimore, MD
Ross, yes sailing slow is quite helpful when you're making a meal or using the head. Otherwise I usually, but not always, have it trimmed to go as fast as I can. If I'm entering an unknown area such as an anchorage or marina, or encounter heavy power boat traffic then I use the engine. I want as much control as possible and just you're not going to get that under sail alone. Now if I'm entering an area I'm familiar with I love to go in under sail. Nothing like impressing the masses with some good sailing skills.
Mike
Macgregor 21 Clinton, NJ
While I like to go fast sometimes, the Admiral is a bit of a 'nervous nellie' and since I learned on little(er)boats like the snark and a 17-footer, I had to be able to de-power pretty quickly. To be honest though, When I have no particular place to be I'm just as happy with a leisurely sail and am likely to not leave the dock if it's blowing really hard.
My modest 21-footer is similar in size to your's Roger, but probably due to it's undersized jib I can't get it to heave to for more than a few moments. When I need to depower for more than a few moments the jib gets partially furled first; after that, if it's really blowing I have to bring her into the wind and fire up the iron genny since I still haven't figured out the solution for my boat's poor reefed performance.
Dec 1, 1999
2,391
Hunter 28.5 Chesapeake Bay
This is an interesting question, the answer to which (at least for me) would be dependent on the location, characteristic of the new area being approached, and the actual conditions. If I had enough sea room, and there were not a lot other boats in the area, I guess I would try to depower the boat and remain under sail for as long as it was safely possible to do so. The key here would be making sure I had enough free space to get the sails down. and the iron genny on, if need be. FWIW, I sometimes see people sailing in or out of Herrington Harbour, where I keep my boat. I'm sure they are dazzling their passengers and all those who can see them with their sailing skills. Yet this is a long, narrow, and shallow channel and one that makes it really tough for a boat under power to give way to a boat under sail. While it is a good thing to be able to sail your boat in all conditions, there are times when it just shouldn't be done even if it is technically doable.
Jim
May 21, 2007
775
Catalina 36 MK II NJ
Ross, you have a point. You might want to sail slower to trol fishing or slow up to stay with your buddy. I have never been in this position. I aways want to go faster and blow my buddy away or make time on a long trip.
Ross
Jun 15, 2004
14,693
I once watched a single handing cruiser sail slowly into Rock Hall Harbor and turn and sail back out in the best display of handling a boat under sail that I have seen. That same day a 40 something came in with about six people standing on deck and a Bostom Whaler tied to the bow with about
feet of straight rope. . Six crew and they couldn't bring the boat into the harbor because they had an engine failure.
Sep 29, 2008
1,976
Catalina 310 #185 Quantico
I have managed to sail into my slip a few times. Best time was once when I did it and a few people came running up thinking I was in trouble and I just slid right in and stopped. One of them, a guy name Mike Fallon who used to be one of the top racers on the Potomac, looked at me and sail "That was some nice sailing" - one of my proudest moments.
One other skill that is a little neglected is being able to get way when the wind is really light and you have to make your own wind. Those conditions are a bit tricky and a sudden movement or extreme anything can kill your progress, but very rewarding when you are moving and no one else is.
Mar 28, 2007
211
Hunter 33' Cherubini Biloxi Back Bay,MS
Sailing slowly
The only time I like sailing slowly and quietly is on the way home just when the sun is setting after being out on the water all day long. What I crave and have fallen in love with are the good 15-20 knot winds and seas that are 2-4 feet(or more) it is then that I take over the helm. I am quite fond of a good rain storm or thunder storm out on the water. September and October are my favorite months down here because of the good winds.
No wind..motoring..water that looks like glass..not for me..just pass me the rum!
Autopilot..absolutley hate it.
Ross
Jun 15, 2004
14,693
I enjoy sailing close to the edges of my sailing grounds and going slowly allows us to enjoy the scenery and to avoid running aground suddenly. When the world is as pretty as this I don't want to hurry past.
Edited for spelling
Mike B
Apr 15, 2007
1,013
Ross, is that the Sassafras? It looks very serene, especially with the moon showing it's face in daylight hours. Also have to ask you, since you mentioned "running aground suddenly" , if you've ever run aground "slowly" :)
Mike
Sep 20, 2006
2,953
Slow sailing
Sometimes you just take what you're given wind wise. This was Thanksgiving weekend ( Canadian) on a slow wind day and nowhere really to go. Dumped the kids in the dinghy while underway to get some "action shots" of the boat. Sometimes Autopilot is fun too.
Ross
Jun 15, 2004
14,693
Mike
Mike , We were sailing down the channel from Havre de Grace with very light winds. The wind died and we drifted into the edge of the channel. Nancy had a fit and I started the engine and backed off. I have had harder dockings. That is the north side of Still pond. This was sunset the same day.
