I have a 2qm20 original sea water engine converted some years ago to fresh water. Need a new thermostat, will the one shown for the fresh water engine fit in the manifold housing position
Mike
Mike
Never worked with raw water cooled unit but I would guess the reason is to avoid having various carbonates drop out at the higher temperatures. Create a real mess in there after a while.Those are big differences in temperature.
Further to my original post, I am in the Bahamas at the moment probably cannot get a thermostat. The one in the engine at present is stuck closed. Although the motor never gets hotter than 185f( fresh water cooled unit) would it be better to run without a thermostat, or keep the broken one in.Never worked with raw water cooled unit but I would guess the reason is to avoid having various carbonates drop out at the higher temperatures. Create a real mess in there after a while.
is the hole to allow water to pass through, im not sure what you meantParticulates dropping out.. exactly.. doesn't normally happen in the heat exchanger because the temp of the seawater is a lot cooler than 140F, which is around where the dropping out commences.
Chusansail, it sounds like ya don't have too much of a problem .. I would not take it out.. If it is stuck closed, I would drill a hole in the valve plate to make sure that it is OK..a 3/16" or 1/4" hole should do.
............. because with the advantage of having the factory service manual in one hand and a rum and coke in the other, it looks like you're right within specs.The one in the engine at present is stuck closed. Although the motor never gets hotter than 185f( fresh water cooled unit) would it be better to run without a thermostat, or keep the broken one in.
Mike
Could you explain further the hole drilling, precisely where.Particulates dropping out.. exactly.. doesn't normally happen in the heat exchanger because the temp of the seawater is a lot cooler than 140F, which is around where the dropping out commences.
The carbonates in raw/sea water will quickly precipitate out of solution at near 155°F forming 'scale' in the cooling system (.... or 'rocks' if near an undersea volcano vent). If the raw cooling water never exceeds ~150°, fouling with carbonates is minimized. ;-)Those are big differences in temperature. Anyone have any reasons why the engine would require such a difference for respective cooling systems?
