There’s a hole in my boat
Mar 2, 2019
568
Oday 25 Milwaukee
I also have been convinced to removed all the through hulls ..I will be watching your progress
Mar 20, 2015
3,212
C&C 30 Mk1 Winnipeg
Also my plan this year. Time to redo the anti fouling so may as well deal with the 2 superfluous thru-hulls at the same time.
You go first !;):biggrin:
Jul 12, 2011
1,165
Leopard 40 Jupiter, Florida
Hole's gone - time to go sailing! Good luck with your G 26 - a fine boat that I've spent many happy hours on. She'll bring you home.
Aug 17, 2013
934
Pearson P30 202 Ottawa/Gatineau
now I have to let it dry and do the fairing on it.
then I need to figure how to add a valve to my head's intake through hull, it's a ¾ inch with hose barbs, no thread to screw a valve
Aug 17, 2013
934
Well I finally had time to sand the patch down, it has a few low spots but all in all a nice job
Likes: rgranger
Tom J
Sep 30, 2008
2,322
Catalina 310 Quincy, MA
What kind of valve? Is there just a through hull fitting with no shut off on it? You can get in line valves for the 3/4 hose, but that won't work for a through hull shut off.
Aug 17, 2013
934
hey guys and gals, quick question before I slap a coat of ablative paint on the hull, do I need to apply gel coat to my patch before I paint it or just paint it and be done with it?
Sep 25, 2008
7,345
Alden 50 Sarasota, Florida
The bottom paint doesn’t act as a barrier to water - gelcoat does...
I didn’t read previous comments but if your patch is glass and resin, it should be sealed with gel/epoxy.
Use an epoxy primer not gelcoat. Gelcoat is (usually) polyester which is not as water resistant as epoxy.
The epoxy primer will also have instructions for hot-coating the anti-fouling to get a good bond.
I don't think you want to hot-coat ablative. That is more appropriate for hard anti-fouling paint.
