Teak & Holly laminate flooring
4
S2 7.3 Northern Lake MI
I am considering putting onto cabin floor teak & holly laminate wood 12 mills with veneer of 2 mills. Will 2 mills thickness hold up? How many coats of epoxy would you recommend? I appreciate the input
Sep 25, 2008
7,737
Alden 50 Sarasota, Florida
veneer
Why epoxy as opposed to poly or something like Ultimate Sole? Both of them should be preferable unless you are talking about the bottom to preclude water penetration. I'll leave it to the wood experts to comment on the veneer. The advantage of using the Ultimate Sole is that it will protect the wood as well as poly but be less slippery when wet. We put that on our shower teak floor and it works great.
Feb 14, 2008
4
Ultimate Sole
Don, Wasn't fimilar with ultimate Sole. Looks like a much better way to finish the venner. Thanks
May 1, 2005
107
Beneteau Oceanis Boca Raton, FL
Just completed
job of teak & holly veneer. I used west system and contacted them for advise. The said three coats of epoxy on both sides and the edges. Then three coats of varnish on the teak side. I have photos of some of the problems I ran into listed on this site. Search for teak & holly, and sole. The reason for coating all sides was the fact that if you try to coat the back only, the wood can warp from moisture exposure if the unfinished side is not coated quickly after the epoxy is applied.
Ross
Jun 15, 2004
14,693
Mike , Do you mean 12 millimeter plywood with a 2 millimeter veneer?
12 mils is like a manilia file folder.
Feb 14, 2008
4
Teak & Holly
Ross, The plywood is about 1/2" thick. I was using the size stated by sales rep. I May misunderstood him and that he meant the veneeer was 12 mills. Mike Kerry, I'll look up info on this site - Thanks, Mike
Jun 3, 2004
890
Hunter 34 Toronto, Ontario Canada
Most likely
12 millimeters. That is about 5/8" from the land of metric and from one who spans both systems because of my age that is My claim to bilingualism
Feb 6, 1998
11,772
Richard..
Your bilingualism might need some more fine tuning..;) 12mm is .47 inches or just shy of 1/2 inch
Jun 3, 2004
890
Right you are
Maine Sail. That is the trouble with being "bi-systemual"- some times you get them BOTH wrong!!
