Thanks Rich, this is really good stuff and puts it in perspective. I'm heading back to the boat to look it over with pictures to be taken.Neither options will get what you want.
If you do a lot of long distance cruising or cruise in the 'remote' places of the planet and NEED an onboard recirc. polisher, we can help with your design ... otherwise I suggest you buy a 'case' of paper towels and a long handled scrub brush. If after tank cleaning the tank quickly (1-2 years) forms a lot of 'sludge', then consider to put on a recirculation polisher.
Rx: Clean the tank (as clean as your mothers dishes), then see how long it takes before you need to clean it again, then make a decision to add an onboard 'recirculation polisher'. Filters cannot 'clean out a tank', they only clean up the oil not the crud thats stuck to the tank walls.
All U Get
