Dave
When tacking I cannot get an even point from side to side. When on a port tack the point seems reasonable, but when on a starboard tack the point angle falls off 15 to 20 degreesbeyond where the point direction should be. I have new sails, stays all around are tightened properly, the keel and rudder are aligned properly. What other things should I look into?..Also, the traveler is in the same position on either side and this is a constant problem in varing wind speeds and directions, so it is not a wind shift problem.
