Synthetic Wood Coverings
130
Lancer 29 Kemah Texas
I hate spending money at West Marine because they are SO over-priced on everything.The local Home Depot caries spools of Anchor Marine Grade wire for $3.67 a spool..West Marine sells the same wire for $19.99 a spool.Still,I do swing thru the local W/Marine for a magazine and such from time to time.Hence my querry. I was there couple days ago and found thier brand of Synhetic Wood Varnish on sale..normally this stuff goes for $29.00 a quert..on sale (they call it "a promotional")it was only $6.00 per quert.I am in the process of completly redoing all the interior wood on my Lancer 29..and at $6.00 a qt. this stuff is cheaper than anything else.even the MinWax Spar Varnish I was going to use on the inside and WAY cheaper than the Cetol Light I was going to use on the exterior. My question is this; Has anyone used the West Marine (made by Epiphans)Wood Pro Plus on thier woodwork and what kind of results did you get with it? I bought 6 Querts of the stuff..more than I need but will find some other uses for it,I'm sure.
Jun 2, 2004
3,648
It is Here
Makes you wonder about the prices on other stuff there don't it.
Feb 6, 1998
11,759
Rick what is here?
I'm confused by your post? What is it you are referencing Wood Pro or the wire or....
Jun 2, 2004
3,648
Home Depot Carries Anchor Wire and Connectors
Sorry, It's early
jimq26
Jun 5, 2004
860
Manufacturer's name is - Ancor Marine
not anchor. Rick - where did you find it at Home Depot? Doesn't show up on their website anywhere that I can see?
Jun 2, 2004
3,648
Ancor is Right and I knew That, Again It's Early
The two HD stores out around here have a large section on two end caps in the electrical department.Perhaps they only stock it in coastal areas?
Jun 4, 2004
174
Oday 272LE Newport
Home Depot is sometimes unpredictable ...
in Marathon FL a few years ago they were selling stone crab traps and crab trap buoys ... the local managers must have some room to improvise. Vic "Seven"
