Survey says blisters
JerryP
Jun 6, 2000
11
Hunter Vision-32 Mayo, MD
3 dime size on hull. Is this a problem or not. Should I buy this '89 Hunter? Thanks.
Rick D
Jun 14, 2008
7,206
That's Nothing
The surveyor should have told you that. RD
JerryP
Jun 6, 2000
11
blister problem?
Okay 3 is nothing but is it or is it going to be a problem? Do I have them fixed or what? Thanks
Sep 25, 2008
7,733
Alden 50 Sarasota, Florida
small blisters
Jerry Three small blisters usually are not a prelude to bigger problems. Just open them up, grind down to good glass, let the areas thoroughly dry, fill, fair and seal them. If the problem recurs next season, you can barrier coat the entire hull which is good preventative maintenance. There is always the other viewpoint that says - why buy one with blisters when there are so many others for sale with no issues? Depends on the overall condition of the boat, the deal and how much you really like this particular boat.
Jun 7, 2004
944
Birch Bay Washington
Grind them out with a dremel tool
dry with a heat gun, fill and fair with some thickened quick set epoxy and paint it. If you want to be obsessive, you can add some aluminum powder to the epoxy mix. Three small ones are not a problem. One hour to fix - maybe less.
Dec 25, 2000
6,063
Hi Jerry, my marine surveyor said not to worry...
about dime size blisters. He advised me to just open them up, let them dry out and use a scraper to remove any loose bottom paint. Then sand and feather the edges until smooth then apply bottom paint. No grinding into the glass is necessary. Terry
