DENNIS
We are in the process of purchasing a 30", 77 srfk. We had a survey doneSaturday and in the process the major item of concern was:"Elevated moisture readings and slightly dull soundings were noted in the following areas."A) The cockpit floorB) The port side cabin top around the mainsheet turning block. (also signs of interior leaks)C) Both side decks along the cabin sides.My question is: Should I stay clear of this boat? Or is there a rule of thumb as to some cost of repairs? How difficult is it to fix? Other than the above, the boat got a fairly good report for being an older boat.
