My boat is an the dry on a DIY marina intending to do the usual maintenance like replacing the lines going under the waterline (CB ands rudder), bottom painting, polishing and waxing, on outboard engine oil- and gear change, replacing the impeller, etc.
I got told it comes most something else up. Well, it was not pleasant to discover a damage on the bowl. The upper deck part separated from the hull.
My question how to fix it the best; using marine-tex, fiberglass resin or two component epoxy
pressing into it and releasing the forestay-pull to get both parts tight together. Maybe placing some bolts through? Advice is appreciated,
Hart
Hart
