support under deck organizer
Mike Whalen
Okay, I've finally order new halyards, blocks, deck organizer and rope clutches and I have a halyard organizer to run my lines aft. They come from Rudy's (except the halyard organizer) I ordered a triple organizer and a triple clutch. I forgot to ask for advice on installation. I'm not sure what hardware comes with them but do I need a plate under each? Can I use aluminium? (I have a source) or do I use wood, steel? They will go on the cabinroof starboard side. Hoping to do the deed in the next two weeks. Thanks, Mike
Paul Palmer
Support for deck organizer and clutch
Mike A plate under each would probably be the best but I just used stainless steel fender washers. It is working fine and a lot faster and easer. The only place I could find to mount the deck orgainzer, that would work, was right over the bulkhead. I ended up with a through bolt on each side and a wood screw in the middle. It is a great addition to run the lines aft. Good luck with your project. I have posted photos on the photo forum of my set up. Paul Palmer
Jim Stanford
Paul, A question on your pictures?
Paul, What's the 3rd line in your pictures?
